Repair panels
mopargeek
10:37 PM
mid atlantic
Anyone know of a source to find upper & lower wiper cowl panels (right side) for 64 Belvedere? Already purchased LH side from vendor @ Carlisle. Can`t seem to find RH side.
I have repaired a number of these early Cowls ,I didn't know they made a RH cowl repair panel ,It is usually the left side of the cowl that rots out ,Ever time I needed a RH panel I would have to find a Doner car to get it from .Good luck .
Thanks 426sfc, After removing dash assembly i found rust damage on lower panel! Any tips you could share when repair is made? Is their a drain area that gets plugged over time and leads to rusting of panels.
The right side of the cowl drains out behind the right front wheel behind the splash shield .It normally drains good ,The left side of the cowl is a different story .It drains out under the top of the left front fender up high ,it is a very small hole and plugs up easy and rots the left cowl .The right side normally holds up good ,But I have repaired them with Doner parts from any 64 of 65 B body plymouth or Dodge ,rift side parts should not be too hard to find as they hold up well.
IMG_0510.jpgI had to make 5 patches to repair my right side.
Mike
