Brianproctorla
Hi everyone.
I own a 1973 plymouth satellite with a 318.
The carb is a carter 2 bbl.
Recently, i have been having problems getting the car to run properly.
I had old gas issues, which caused me to swap the tank, filters and fuel pump.
I also had the carb overhauled.
I have a problem with the car stalling in drive.
I suspect a vacuum issue or an improperly tuned engine.
My goal is to re-do the vacuum lines as they are quite suspect (brittle and patched).
I would like to start with the rear manifold vacuum source.
At present, I have this running to the firewall and the brake booster.
Should it also be running to the port on the passenger side of carburetor?
Where does the firewall vacuum source go?
