mopar73dge
About two years ago I changed my worn PCV valve on my 73 318. I decided to buy that very expensive Gates date coded 11/32 inch hose. I noticed soon after driving the car, the next time I went under the hood to do some cleaning, this after a week of sitting in the garage, the hose was oily at the valve and down a few inches, I cleaned it up. It did it again and the rubber seemed to just wipe off a black film, after about 1000 miles it went to the entire length. This has never happened in the 35 years with this engine until now. I just read here in the forum someone mentioned it was the wrong material hose. You would think that purchasing the reproduction material paying all this money, it would be correct! I switched over to a regular good year made pcv hose, It does not have the lettering, but it works and does its job. I think the oil fumes and fuel vapor blow by must have reacted on the PCV line, maybe my engine leaks more than say a new one, but I decided to experiment. I have the hose off the engine all cleaned up with a degreaser, it was dry. Later a put a few drops of clean oil inside down the end and kept it up ward. The outside I wiped clean and dry. The next day the oil had came through the rubber hose, and it was clean oil! I think this would prove there is a materials problem.
Anyone have this happen on there engine?
