lewtot184
Are you using an early piston with a late head?
			Where are you getting. 030" deck height. I know my 68 road runner was near zero.
No! Factory piston and stock 906 casting. All 906 heads I have cc the chamber of is 86-88 cc.Are you using an early piston with a late head?
Zero is where the piston is even with the block deck. I think you have 67 or earlier pistons, not the 68 or later that would match up the 88cc head. 67 or earlier used an as cast 80cc closed chamber head with a shorter pin height, or your measurements aren't accurate.What exactly is near zero? I measure my factory/stock piston and they are .030 in the hole.
Yes I know exactly what piston to zero deck means, but You said NEAR zero so I wondered were the piston in your -68 engine was in relative to deck hight?Zero is where the piston is even with the block deck. I think you have 67 or earlier pistons, not the 68 or later that would match up the 88cc head. 67 or earlier used an as cast 80cc closed chamber head with a shorter pin height, or your measurements aren't accurate.
There's this for reference..........
[/URL]
From the Chrysler 1968 link.....
You're on the right track, and since you measured what you got, you know what you got.A 383 engine is not a high compression in 1970. If I calculate correct so is has it 8.9:1 with steel head gasket and 8.55:1 with a .039 gasket.
FWIW, It's also in the DC Racing and MP Engine manuals............Thank you, Interesting here is much info.
This chart shows the 68 383 piston .021 above the deck, not below, for a blue printed engine. Mine was right at zero for a non-blueprinted engine. I you guys are off base on this.There's this for reference..........
NHRARacer.com - NHRA Engine Blueprint Specifications
www.nhraracer.com
Now to the problem, its leak oil betwen head and block in the rear ( cyl 8) I was thinking to pull of the heads and mill them. The run time is just a cuple of minutes, can I reuse the shim/steel head gasket?
Thanks!
??........I you guys are off base on this.
I looked up the specs that Mopar gave NHRA on 68/69 383 4 Brl.
Deck................021. ABOVE BLOCK
Gasket.............020 THICKNESS
Head................79.5 CCs
Of course, these are minimums if everything is perfect and that
is how we blueprint these engines.
Specs are always provided by the manufacturer. Who else would have them?The stock factory stuff is never even close to the minimm/maximum spec. Years ago NHRA records were lost. They asked the company's for specs. Lets just say the specs furnished by Chrysler were creative.
Thanks!
