Hey folks. So, when I set the front end height I left it a on the low side, because I liked the low-front end look and it rode and handled fine. Another post on here(by 70bronco) got me curious about the actual number...well I was at 1-3/4", and then upon re-reading my FSM it shows measurement 'A', the height to the adjuster blade, always being greater...well on mine 'A' was the lesser measurement. I was smashing the bump stops a little. So I brought it up and the difference in heights got smaller as I raised it. I jacked it to the point that 'A' was greater than 'B' and got the 1-7/8 spec and the car was nose up like the General jumping a creek...what the hell. Put it back a little higher than I originally had it, just off the LCA bump stops and it rides a little better(like I figured) and actually hooks better with the little extra preload on the rear--see pic for current setting(B is again greater than A..)
It rides/handles great and sits as high in the front as I can stand it, has a slight slight rake, kind of hard to tell in this pic. The front end was rebuilt with a pst kit years ago, so the knuckles aren't OEM...XHDs on the rear. Tires are 28" tall out back and 27.5 in the front (that shouln't matter though right)..spindles were part of the right stuff disc upgrade kit, could that be it?
