Right front wheel noise
tahoeharley
New Member
7:42 PM
queens New York
Gm I have a 1973 dodge charger one owner car it was sitting for a year took it for a ride and was making a clicking Sean on the right tire change the rotors calipers pads bearings still making a sound. What do you think it could be front end NEW it just started out of nowhere.
Go to the tech section of the sight, on down the page from here.
Re post in driveline or steering / suspension threads.
Wag , could be a bearing or backing plate making contact.
Did you knock out the bearing races too? Had one that was cracked and it made a clicking noise....
This will sound dumb.... but check your wheels nuts also the lug holes on the wheel.
Ive seen a wheel with worn holes that the nuts can be tight but the wheel can still move.
I had a spare tire that was clicking. Turned out to be a wheel weight on the inner rim rubbing on the upper control arm or ball joint.
My Dakotas do that but they have 8" wheels on them....and the sound is pretty pronounced.
I did that and changed the rotors and new race and bearings looked at book to make sure to torque it down to 9 lbs like book said it had it one day out of no we’re
