Jim Kent
- 5:36 PM
- Mar 24, 2018
- Sioux Falls South Dakota
I installed right stuff disc brakes above on my 65 Satellite. Front brakes grab for second then let go replaced master cylinder with same master #DBMC15. Bleed brakes but still having same results with second master with front brakes grabbing but then even with brake peddle down I can spin wheel as brakes release. Once you release and push down it grabs for short second then releases? Is there another dual master cylinder that better or works? Brother thinks I should get a 1500 psi gauge and check to see if pressure drops? Back drum brakes work fine. What am i missing Jim
