Roadtrip Prep
dfrazz
12:49 PM
Denver
Heading out soon on a 271 mile roadtrip from Denver to Creede, CO for their annual car show. To me, the drive is the fun part and to make it more enjoyable I try to prep the car and pack tools/supplies for issues that may come up along the way. Besides a AAA card and cell phone, what you do in preparation for a roadtrip?
I just did a 300 mile trip last weekend. I've got a tool bag in my trunk with wrenches, little bit of wiring and connectors. I always bring some oil and water. I carry an extra ballast resistor and an ECU also. Fire extinguisher.
Nut and bolt check. Fluid check. Brake check. Torque lug nuts. Secure hub caps. Check belts. Tire pressures. Exhaust hangers. U joints. Clean slate, ready to rock and have a fun, uneventful trip, 95% of the time.
I give my car a little rub on the dash and give her a few words of encouragement…. then hope for the best!
I took my Charger there 21 years ago (1st pic Cobra car show in Creede, 2nd pic is from road through Spanish Peaks from La Veta to Trinidad). My car was mechanically restored, but wiring, etc was still original. I was on the side of the highway during that trip. Turns out I had the alternator harness routed between the RPM heads and the distributor cap. Somewhere between Del Norte and South Fork it shorted and burned the wire from the alt through the bulkhead connector and back to the starter relay, smoke everywhere! Luckily I brought a big enough wiring kit to tear out the burnt wiring and put in a temp solution. Had to go to back to Del Norte for an alternator at Napa.
I think things would be different 21 years later, not as many parts for our cars at the parts stores as back then. I believe the parts you could get back then were more reliable too. In addition to things listed in the above posts, I'd bring tools/parts to bypass things that might fail. Example: Hole in a brake line or radiator tube? Use needle nose vice grips to bend it over itself and clamp it off.
When my car caught fire, I had the battery cable clamps loose enough to remove quickly by hand, otherwise my car could've burned to the ground. Which brings us to having a fire extinguisher.
Tools, oil, water, fuel filter, jack, gloves, moving blanket to flop on if you have to play in the dirt or large piece of cardboard for same, v-belts or their sleeves for quick sourcing if needed, fire extinguisher, flashlight.
Assuming the car runs fine i would only check oil and coolant if its only 300 miles. :D
Bring any spare parts that aren't readily available. For example, if you have an MSD ready to run, bring an extra module.
Windshield mount for a cell phone, gps/tunes.
USB charger, either hard wired or lighter plug.
Does the spare tire have air?
Small cooler, accessible while driving.
A good co-pilot helps.
Don't over do it or overthink it, if the vehicle is prepped and ready you're good.
If you pack a bunch of crap the 1 thing you didn't bring is what you'll need.
People used to drive these cars all over the country, 4hrs is nothing, enjoy it.
That's great you were there 21 years ago! My first trip was 2018 and for a few years we parked at an angle down the street which was cool but very narrow for driving in the middle of the street. They switched back to parallel parking a few years back.
You can't take all possible parts with you and you are right, it will be the one thing you don't bring that will break lol. My spare has air but it is the original spare tire from 1968 so....
I found an article from years back in Mopar Action magazine by Rick Ehrenberg titled "Roadside troubleshooting your Mopar, or when to call Dr. Hook". He lists the following tools and parts which I think is a good list:
TOOLS TO BRING
  • flashlight
  • wrenches from about 3/8" to 3/4"
  • set of 3/8-drive sockets with a ratchet two extensions
  • screwdrivers
  • small pair of pliers, a
  • long-nose pliers, a
  • 6" or 8" diagonal cutters
  • 10" Vise-Grip
  • medium-size ball-peen hammer
  • 25-implement knives
  • 3 "clip leads" (3 or 4-foot lengths of approx. 18-gauge wire with alligator clips at each end)
  • DMM (digital multimeter)
  • brake cleaner, ether, and WD-40
  • few feet of neoprene fuel line
  • some clamps
  • half- dozen assorted cable ties
  • spool of 16 or 18 gauge steel "bailing" wire (for wiring up exhaust, linkages, etc.)
  • roll each of electrical and duct tape
  • gallon of 50/50 antifreeze
  • battery cables
  • cell phone
PARTS TO BRING
  • spare ECU and ballast resistor
  • distributor and coil
  • spark plug wires
  • belts run your alternator and water pump
  • hoses
  • wiring
  • switches
  • fuses
  • stop leak
  • brake fluid
I just google street-viewed Creede and it looks an awesome little town. Should be a great trip.
I did Power Tour this past spring.
Day 1 we drove 8.5hrs, and weren't even there yet. Day 2 was 5.5hrs.
I brought some small spare parts, the tools to change those, and misc tools.
Screwdrivers? How many does one need? I brought a Phillips to change my cap, and a flathead to take up space.
Bringing parts, such as a distributor, seems excessive.
Bringing wire to tie your exhaust up, either you're planning on doing some Dukes of Hazzard ****, or fix your exhaust/take preventive measures before you leave
I actually inspected everything, 1 rear exhaust hanger looked a little worse for wear, so I put some metal strap a bit longer on all of them.
The thing I used most was windshield cleaner in a spray bottle and a rag.
I wish I brought cheese/meat & crackers.
If you drive your car on a regular basis.
Check fluids, tires , and bring your normal car tool box.
Always, that extra ballast resistor :drinks:
It's the dumb stuff I forget like a phone charger ect.
Have a great time !
Yes! Electrical parts.
I took an 8 hour drive in my truck this past weekend and the new voltage regulator smoked my battery, literally smoking.
My new voltage regulator, installed on my truck, before I left, quit on me.
Luckily parts store nearby and someone offered to bring me.
That reminds me, I should put another new one in the glovebox because new electric parts are garbage.
