Rocker arm wear
69440yellow
10:41 PM
Springhill FL
Please look at the pictures and tell me if the wear on these rocker arms is normal. These came of a 318 hydraulic lift motor. I took it off to look for cause of loud tappet noise. I found that if you push down on the push rod the lift will push down with a moderate push of the thumb. The spring brings it right back to the top as you receive the pressure. The main question is about the wear on the rocker arms.
