Rocker trim holes
tom jaffeux
10:06 AM
hampton,VA
Good morning FBBO hope all had a
good Christmas. I have a question about installing new rocker trim 68
satellite need hole locations in quarter panel and front fender them parts are new. I have the holes under the doors,and where does the metal clip with the wire hood
Thanks for the help
Thanks for the pictures that helps a lot. I have one more question the metal clip go vertical or horizontal?
Thanks Tom
Sorry question lol. Any details on how to install the trim like what’s the gap at the fender and quarter looks like a 1” and do you install the clips on the car then snap the trim on?
Thanks Tom
Insert the plastic clips into the rocker first. Then snap the trim piece onto the clips.
Yes , install them on the car first. Use a chalk line to mark your line. If your metal clip has the threaded stud on it, it can be installed in the molding first. If I remember correctly the molding hooks at the bottom and snaps at the top. Straight chalk line is Crucial. Pul a chalk line across the holes and snap the line.
Thanks very much for all information it will make it a lot easier i was little worried is I’ll mass it up now I understand
Thanks Tom
The spacing of the clips is not critical, having them in a straight line is.
nice photos of the blue car above.
Thanks for all the information Mr Cook
it was a big help after following your instructions it was not that bad here is a few pictures
Sorry to bother you with another question, just got the rear hood seal have issues with the way is installs clips facing forward or rear look a pictures.
Thanks Tom.
You are becoming a life saver
