Rt/se badging
robocop1971
2:59 AM
lucasville
Alright need to know if the s/e badging was on both sides of sail panel on 69 rt/se charger? Any info would help Thanks!
I'm not 100% sure, but I don't think so. I think it only had the R/T emblem buy the back side marker or in the tail stripe. Also if it had the door side scoop, the R/T was displayed there. I think the "charger" emblem was the only thing on the sail panel on those years.
Do you mean inside and outside or left side and right side.
I think the SE badge (the same one used on 67 Coronet 500 SEs) was on the outside of both C pillars on 69 Charger SEs, but I can't say 100% on a car that was both R/T and S/E.
Both outside c pillars, also if it requires them is ther a left and right side?
If you own a 69R/T SE CHARGER the rear sail panels will have emblems on both sides stating it is a SE model.Usually these cars came with A/C deluxe interior, and the vinyl roof.Your vin code should start with XS29, THE 3 NEXT DIGITS SHOULD BE THE ENGINE SIZE IN YOU CAR. IF you need pics to show i can send you some before i started my resto.
I have an rt/ se xs vin......but when I bought the car it was a basket case with 1 badge in a box. I since replaced full quarters and unsure if they were on both sides and is there a left and right side. Any pics would be great. Thanks!
Here are some pics of right and left side of a R/T SE with se badging. this will give you an idea of placement on your new quarters. as far as i can see on new badges there is no difference on left or right and looking on car at old ones. hope this helps Steven
Oh yes Thanks a lot!
Could I get you to measure from the drip rail molding over to the edge of emblem?
Thanks!
It is 2 3/16 inches from middle of curve on drip rail to edge where it says special edition on the emdlem
