S/S Spring ?s
72Fourspeed
8:30 PM
Idaho
Does anyone have the numbers stamped onto the SS Springs ? I found a set a guy took off a Challenger that he wants to sell reasonable. I can`t find any #s here via the search. I want them,but only if I can pin down what weight car they are for. They are 20 inch on the front half,So I`m sure they are the real deal. Thanx,Don.
Try Mancini Racing the site has MP S/S springs, see if the #'s are near the same, the B-Body front section is 22", you will need some different front S/S spring hangers for the 20" front spring sections, they sell them there also, both the springs & hangers are pretty damn cheap new... A set of Calvert CalTracs Bars $369, with your stock springs & front spring roller sliders $69 each, would probably be a better overall investment... Unless your dead set on the Super Stock springs, which are only like $220 new, for just B-Body S/S springs, no hangers etc...
put ss springs on a 64 B Body once and it was squirrely as heII..
must have been my error...but "stock" springs worked fine.
JMVHO
Springs
My 63 has 20 inch front segments as oem,so no hanger issues. I rode in a 64 years ago with these springs & it flat hooked. Ride was not objectionable. I did find some #s on Moparts. 456 &457 are 3400 lb & 454 & 455 are 3800 lb.
All SS springs have 20" front segments.Thats why b and e bodies need special front spring perches.Like the ones in the pic.You can get away with running standard perches if you run smaller tires.
I run the 002 and 003 SS springs,pinion snubber,spring sliders,adjustable spring perches,and air shocks.Consistent 1.55 60ft foot braking on a 9"tire @3700 race weight.
