Safe to swap pistons?
Bladeruner69
3:13 PM
SF Bay Area
So I built a 500" 400 block based stroker 10 years ago and finally got everything up and running earlier this year. The problem that I am having is the static compression ratio and pinging under heavy throttle.
I have flat top pistons and 88cc heads which gives me a compression of 10.8. My engine builder told me that I should be fine with thicker head gaskets but nope. I have mix or use an octane as is.
My question is, with very low milage(less than 100) and hours am I able to swap out for some dished pistons and use the same rings to bring the CR down without machining the block?
How thick are your head gaskets now? There are a lot of different thicknesses available.
As much as I strongly recommend against it there are shims available for such ..
https://www.summitracing.com/parts/fel-8519sp/make/dodge
As toolmanmike ask,, what is current head gasket thickness?
standard steel is about .020 compressed..
Fel-Pro blue is about .040 compressed...
In answer to your question , yes , you can use the current rings again...
HOWEVER....
Strongly recommend doing a quick hone before reinstalling..
What heads are you running? 88cc sounds like Iron heads & if thats the case you'd be better off swapping to aluminum heads
E85
water/ meth injection
dist curve?
going to closed chamber heads there is still the compression
Laugh out gaskets has what you need. The gasket they have can lower your compression Rachel about one full point
I agree with Wild, which heads have you got? my 500" EDE RPM head motor worked fine on pump 93. Timing was a conservative 36*, all in at 1200 RPM, just off idle. Which gaskets are you using? Seems like 10.8 would be tough with iron heads. Even with iron heads & head gasket thickness, the right cam could help.
More duration will lower that static CR.
Mike
change your heads. use aluminum you will never get away from pinging with iron unless you use 100 octane gas. I don't care what anyone says....
If you have open chamber iron heads, you already have no quench, so.... summit has cometic mls gaskets at 60, 75, 90 and 125 thousanths thick. Decide which one you need to get the compression ratio to where you want it, and install. They are NOT cheap, but a hell of a lot less money and work than a new set of pistons.
If you have a 4.375 by 4.15 engine with 88cc heads, a typical.025 deck, flattops with a .041 felpro, that calculates to a 10.8 c.r. A .125 cometic will drop that to 9.16 to one. Other adjustments in between are available. Around $250/pair.
What cam is installed?
So far we are only guessing, not enough info... My earlier post about what heads for instance, he could be running open chamber Edelbrocks at 88cc or it could be iron.. Either way it's a poor choice since there's no quench.. What cam? A bigger cam might be the best option... Or not..
Tell us about your build...
No offense....but you need a different engine builder! 10.8 static and (maybe)no quench, on that lovely northern CA gas? He shoulda knowed better! But, we don't know which heads you have; are they already aluminum? They make them with 88cc chambers. Don't know your piston height, cam timing, ignition curve and timing, is it properly tuned(not too lean?) Anyway--if a piston swap is what you desire (proper pistons will definitely fix your issue) you shouldn't need any 'machining' with bores that fresh..Rings are the cheap part of the equation..
Wild, I wonder how much difference the quench really makes. I don't know, but on my bracket motors, I used both the 906 & 915 heads, equal porting milled to give almost the same static CR, same cams. Both combos made nearly the same power based on actual ET/MPH. The quench difference didn't seem to matter. Any thoughts?
But OP does need to give us more detail.
Another thought, have you done a simple compression test to see what the cranking pressure actually is? What if it's really only building 140/cylinder? Then there's something else causing the issue. I'm not saying you're wrong on the info of your own engine, but these things need to be verified before spending the dough and/or tearing into it.
If your running high enough octane fuel quench won't have a huge effect on total power output...
It does on the ability to make more power with lower octane fuel without damaging the engine... And for a street driven car it can give improved throttle response at lower rpm..
