Seat belts
Johnny Z
2:53 AM
NW Ill
I have a 67 charger with a 66 interior. What brackets do I need to mount the seat belts? I found a slot on the lower side of the counsel, and located the mounting bolt. Is there a bracket that gets bolted to the fennel and the belt anchor bolt to it? Any help will be appreciated! Thanks
They really just get bolted to the floor with bolts that let them rotate (anchor bolt).
thanks. I found a diagram for the 66 counsel, and there is a seat belt bracket that brings the anchor point outwards to the side. I need to find those brackets. Let me know if there available. Thanks
Looking for a set of these?
Ah, yeah. Would have to get off another car or if someone has it already taken off. Or make one? I have a 66 that I will be bringing home to get parts off in the spring.
Well, let me know if you’re willing to part with them, unless someone has a pair available. Let me know. Thanks
There's just one on the drivers side because of the trans tunnel offset. And it's welded on as part of the car.
When I converted my 67, I just used the original hole and it works perfectly fine.
Thanks for the info. Did you just feed the belt through the slot on the rear counsel?
