- 12:32 PM
- Jan 11, 2022
- Fredericksburg, VA
I have been dealing with an electrical situation on the GTX. I noticed that the brake lights don't work. There are actually two problems. One is the switch doesn't make contact with the brake pedal to turn the lights off. That I can address. However, when the brake light switch is connected it immediately shorts out the fuse. If I disconnect the brake light switch and install a new fuse, the interior lights (on the same fuse) and other associated electrics work properly. The second I connect the brake switch the fuse blows again. Could this be the fault of a bad brake light switch or a problem somewhere else? Seems to me there is a short somewhere in that circuit, but I am not sure where it could be since the entire harness in the car is new. Would appreciate any recommendations or advice you guys might have.
As a side note, the turn signal switch seems to have stopped working completely, not sure if the brake light issue could be connected to that problem. The turn signal switch is brand new.
