Solid Aluminum vs Solid Copper Crush Washers
Moparfiend
8:59 AM
HOT
Was looking for those hollow copper crush washers but they are getting harder and harder to find. I can lots of solid copper and aluminum. So I assume aluminum have a lower torque since its softer. Wondering if both are good for PS fluid environment. Both I assume for oil drain plugs.
Opinions?
Hit a hydraulic shop and ask for the gaskets for BSPP (British Standard Parallel Pipe)
The first time I ran into it I asked every where and the a hydraulic shop said we have and the bin had lots of dust in it
Single use intended, in reality many use them a second time if need be.. but not recommended. Generally used for drain plugs and the likes.
yup those are the type of crush washers I was looking for. For sure those are single use as the hollow section is what gets crushed.
