- 10:02 AM
- Dec 4, 2009
- Pasadena, Texas
Hope plug was hot enough.Just hook it to your MSD ignition system using the right rpm pill....will have to change the plug from time to time.
Probably shifts like a Champion.Just hook it to your MSD ignition system using the right rpm pill....will have to change the plug from time to time.
You may get a spark when you put in reverse.....Probably shifts like a Champion.
Going back in time to April 1st.Just hook it to your MSD ignition system using the right rpm pill....will have to change the plug from time to time.
25! Day gotta be heavy duty!Going back in time to April 1st.
Do you recommend using 7mm or 8mm leads?![]()
