Pugly
I have a hard time filling up my 66 Satellite, the fuel always seems to run back out the filler unless I go really slow on the pump. Sometimes I can angle the filler just right (as in upside down) and I can put some gallons in normally, but even then it will start backing up the fill tube and start leaking out. It's been this way since I bought the car.
I have read that this is probably a vent problem with the Vent tube that runs from the fuel neck into the tank, maybe the hoses are collapsed or some kind of blockage.
So I pulled the Fuel Neck and Vent tube out of the car and even though the hoses are old, there is no blockage. The Last metal part of the vent tube would not pull out of the tank, so I blew compressed air in it and it didn't appear to be blocked.
I have new elbows to put the car back together with, but would like to know is there something else I need to do before I put it back together, or what might the problem be.
Is there a sock on the vent tube hose inside the tank? and maybe that's why it didn't want to pull out? Or am I missing something?
Thanks in advance.
Thanks in advance.
