Virg464
Looking at converters for my car and came across one from "TSI" (3000-3400 stall) which is sprag-less. I know the sprag works like a ratchet, locks in one direction and unlocks in the other, and helps with shifts? What I don't know is if "sprag-less" is a good thing or a bad thing, or if it just depends on the application? The car is a 66 coronet, +.030 bore on a 400 block with hyd roller cam, mid .500 valve lift, alum heads (10.5-1 CR). Not a monster (by any means) but should be a good runner, but I have no idea as to whether I need/want a converter with a sprag or not? Any recommendation from the converter guru's will be appreciated.
