Starter issue
71roadrunr
New Member
2:56 AM
Fox crossing WI
I put a new starter in my small block Mopar and the wire from the starter relay to the solenoid didn't fit on the stud on the solenoid so I flipped the wire around. Would this cause the starter to engage when I connect the battery or do I have a faulty solenoid or starter relay?
How can you flip a wire around? Only two wires. Big wire battery feed goes on the large stud and the small wire from the relay goes to the small stud.
Can’t you file it out to enlarge?
I think he means can you turn the wire over. Sounds like doing so has created contact between both terminals and that be your problem. As suggested, try filing out the hole in the wire end a little at a time u til you can attach it the right way and then not have it touch the one from the relay.
Ok, looking at your 1st post again... ( Also go to the Welcome Wagon forum and introduce yourself ) Are you saying just the solenoid wire itself between the relay and the starter is the issue and you are asking if it is Ok to flip that wire between the two ?
Don't discount that new starters and solenoids are 50/50 good at best these days.
