Static Timing
PolaraFury
5:02 AM
MN
So I set the timing gear in and got the distributor set with the rotor pointed at #1 cylinder
when I set the cap on the distributor assembly, the rotor is pointed at #4 (inside the cap)
Am I off or do I need to adjust?
Thanks
number 1 is in the 5 o clock position looking down at the distributor that's where the rotor should be pointed
I should point the rotor at the #1 inside the cap and not at the #1 cylinder?
If you are working on a big block.
I like to point the rotor at #1 with the crank 10-15 degrees before TDC........ they always start first shot with zero drama
make sure you are on the compression stroke
The rotor does not know where #1 cylinder is. It only knows what tower #1 is plugged into.
Yes it does! It will tell you where #1 is. Put #1 cylinder on compression stroke with timing mark at TDC and that’s #1, the rotor knows. Where you want to put the wire by following that chart doesn’t mean anything. You can move the rotor to face any direction for #1 by moving the distributor drive gear.
Maybe there's a preferred location?? I don't know but the process is extremely easy and I never worried about where #1 ended up unless there was a plug wire routing issue. As mentioned, bring #1 up on the compression stroke.. I personally set it at 12 degrees BTDC then line up a tower with the rotor and that's #1 regardless of where it's at.
This is the one thing that always aggravates me about the TV shows, they constantly have it 180 degrees out.. building drama I suppose? I don't think I've ever had a car not fire right off the bat so no way these guys get it wrong so often:realcrazy:.
Same here, aim small, miss small lol.
geese , such drama over a simple question
Ahh... I think it's just a misunderstanding, pretty sure they both meant the exact same thing just worded it differently.
I think he means he's pointing the rotor physically toward where the #1 cyl is on the block ?
everything will depend of the oil pump/dist shaft indexing. If correctly done... well, will match the one on cap
big block
Small Block
This is for factory stock Dist... Units with Mallory advance gutters will be 80° offset from that ( BTDT )
