Mark1972
So my steering has always been a little loose. This became more noticeable when the LA came out and the RB went in. Entire front suspension and steering components are new, and wheel alignment is fine. Tire pressure proper and equal. I was told there was an adjustment on the steering box. A set screw with a jam nut on it. I located it, raised the front of the car, loosened the nut, and starting tightening the screw. Question. How much can the screw be tightened before you should consider replacing or rebuilding the steering box? I've only gone half a turn, but it didn't really make a difference and I don't want to over do it.
