Mopar Hunter
Mine must be leaking there too, it’s soaked. I know the power steering pump is leaking.
Yep
I'm going to try it when the o rings get here.Ill post how it went.Have a great day y'all.
If I was you I’d be calling Firm Feel if you can get a hold of them. How long ago did they rebuild it?Same issue here. Firm Feel Stage II box.
I didn't use firm feel.I had it rebuilt locally in MI.It was years ago.It sat dry for a long time during the resto. before it was installed.Im going to reach out to them and see what they say.If I was you I’d be calling Firm Feel if you can get a hold of them. How long ago did they rebuild it?
That was for Powertrip, he had his rebuilt by Firm Feel.I didn't use firm feel.I had it rebuilt locally in MI.It was years ago.It sat dry for a long time during the resto. before it was installed.Im going to reach out to them and see what they say.
Thank you. Looks like it can't be done while mounted in the vehicle. So it's another rebuild or upgrade to Borgenson. Decisions decisions.The spanner nut is torqued well over a hundred ft pounds. I'd have to look it up again. I actually used a rounded edge chisel to break it loose.
This is what you're dealing with. There is an O ring under the castle nut. There also a seal under the adjuster locking nut.
Turning the adjustment screw will change the gears endplay/backlash.
There's needle bearings inside the cover.
The adjuster is threaded inside of the cover.
The adjuster is inserted in the slot of the pinion shaft.
You have to screw the adjuster into the cover to install the cover and leave some play.
Then the castle nut can be installed.
Then the seal under the locking nut is installed.
After all of this is done you'll have to set the correct endplay. Just replacing the seal under the nut won't require any adjustment as long as you don't move the adjuster when loosing the lock nut.
