john.thompson068
Another source I found says 100 ft pounds for the three bolts that hold the steering box to the K member. I had the bolts torqued to 90 ft lbs after installing a rebuilt steering box. There is a clunk noise and sensation that comes through the wheel when turning sometimes. I thought it must be the steering box bolts are not tight enough allowing the box to move or flex. I went to torque the bolts all the way to 100 ft lbs and one of the bolts snapped off at around 93 to 95 ft lbs of torque.
Should I be brave and torque the bolts to 100 ft lbs? That seems too tight, and I don't know if 10 ft lbs of torque will make any difference anyway.
This is on a 66 Satellite. What would you do?
- I am going to buy graded bolts from ACE
- I am afraid the K member threads will strip
