Steering column, manual, floor shifter
praesi
1:59 AM
Germany
Hi,
I am doing a bare to the metal restoration of a Plymouth Roadrunner, 1968 with a A833, manual steering and floor shifter. Due to a bad timing, I had two years between the disassembly and assembly of my steering column. Everything looks fine and thanks to this forum, I have found nearly all the information and was able to assemble the steering column.
But for one part, I am not sure where it needs to go... it is a spring, about 3-4 inches long with a diameter that fits over the inner shift tube on the top (to the steering wheel) and to the bottom (behind the lower bearing).
Maybe anybody out there can help me out on this where this spring needs to go. Any help is appreciated.
Regards,
Thorsten
Yes, will be able to take a picture next friday when I am at home from my business trip.
It goes on the bottom of the inner tube - it rides just above the lower bearing - you can usually slide it on the tube, then put the bearing in and secure it with the 2 or 3 screws into the lower bearing. The spring simply preloads the tube up towards the top bearing...
Many thanks for your clarification. Will assemble the column and spring in this way.
Regards,
Thorsten
