Steering Column
blownalcoholhemihead
2:02 AM
Stamford, CT.
Do any of you have a diagram of how the column goes back together for a 69 b body 4 speed. The assembly manual I have only has the column shift diagram. I have 2 pieces on the column the I forgot where they came from. a wave washer which I think went behind the spring and another washer looking thing with 3 or 4 tabs on it. The rest of it I remembered but would like to see it regarless. I don't know who pulled this apart before I got my hands on it and who knows what other things are missing.
When I was looking at the assembly manual It shows an o ring on the column down by the floor plate, but I Clearly remeber when I took it apart there was no o-ring on it. Is this for the column shift or for both?
Thanks for the help
The part with the tabs goes in the upper end of the outside tube , it stabilizes the inner tube at the top , the lower part of the inner tube goes inside of the lower bearing, the wavy washer sits on the tab parts and keeps pressure on the lower bell.
