tjbindy
Have rebuilt the carb, replaced fuel filter and fuel pump.
Car starts and idles perfectly. While the choke is still closed off; engine accelerates well.
Once engine warms and the choke is wide open. . .. car hesitates on acceleration from idle and often dies. If I manually close the choke, the acceleration is still good. I have been told to look for vacuum leaks; have tried the brake cleaner method and nothing is found. Looking over the vacuum lines and there are frankly a huge number of them.
Car still has CCIE Switch, CCEGR Switch, TIC Valve, Vacuum Amplifier, Vacuum Solenoid Valve, NOx Valve and so on and so on and so on. Not sure what all of these do. Would it be worh my while to bypass / eliminate some of these?
What kind of vacuum should I expect? I have pulled some of the vacuum lines off while the engine is running and there seems to be no difference. Seem to have strong vacuum on several of these lines.
Am I looking in the wrong direction entirely?
:angry1:
:angry1:
