Some Car Guy
So just for kick, I went from 66s to 67s and the stumble is pretty much gone once warmed up. However the “response” feel seems to be a tad less although smoother. I’m thinking this might be because of it being a bit too lean and then the mains come in? Don’t know. I was thinking of bumping up the timing so I get about 35° full mechanical advance. But that would put me at about 16° initial, which I’m not sure if that is bad or not. Any thoughts? Also… For those of you who are running stock 383 HP engines with manifolds, is your jetting roughly the same?
Thanks,
Mikey
I doubt you’d have a problem with 16, just try and see. As long as the total doesn’t get over what the engine will tolerate on a given fuel, you’ll be fine. I found my factory assembled 70 383 hp didn’t make any audible pings at 38, but wasn’t smooth. It was choppy feeling. I pulled it back a little bit at a time and settled on 34 total. Felt free and fast with that, no more choppy feeling. I suspect that might’ve been some sort of “silent” knock I was feeling.
I don’t remember the jetting.
