Street 340 build cam options
Tim Chavez
3:27 AM
Central illinois
Hey gents
It looks like the cam is wiped in my 340, had a failed lifter also, looking for suggestions on a good street cam to boost power, but not so crazy that I have to mess with valves, springs, rockers etc, Do you guys have any suggestions? It’s a J head 340 out of a 70 Plymouth that appears to be stock other than being in the wrong car. It’s a stock 73 340 intake, with a throwaway edlebrock 600 cfm carb. Preferably Wanting a kit with cam, rockers new timing set and Under 400 if that’s in the ballpark.
Hey gents
I think people are going to need more info on the car like rear end ratio, weight, auto or manual trans headers or not, tire size as this plays into the selection.
Stock... it’s a 727 from a 72, a suregrip 8 3/4 with unknown ratio from unknown car, a junk set of flowtech headers, stock weight, and tire size isn’t set in stone as I haven’t decided on a wheel yet, they will likely end up some sort of 17 or 18” wheel. , it’s currently riding on somE 205/75r14 Chinese tires
run a compression test
you can't be sure if not rebuilt with different pistons than factory stock
and for street you do not have to have rockers unless you go over ,525lift
are you going to cut the guides for sels and rocker clearence?
cut for sprigs
guides?
good valve jobI can spend rhe money u save on rockers real quick and better spent
what rpm range do you want to run
