ZR9B
I use a husqvarna ( I mean my kid) and it runs great . Im sure the echo and sthill are top notch.
In the market now what are you using and what would you like to be using.
My old gas trimmer is 30 years old and need s to go.
The only brand I use is Roundup. I only "trim" maybe twice per yr.
X2 I went electric also but I don't do more than 20 minutes of trimming. Be aware that you will be buying a new battery eventually. I do like not messing with mixed gas.
I use Trufuel 50:1 non ethanol oil gas blend. Stihl makes a brand as well. It is expensive compared to mixing, but stores well over winter if you forget to drain or run the gas dry.
