Stripped pulley hole on balancer ok to helicoil ?
dart14
11:59 PM
kemblesville, pa
Is it OK to helicoil a stripped pulley hole on the harmonic balancer or is there too much rotation and stress on the pulley ? Stock 1969 3018 that doesn't see high rpm's.
Would use some kind of lock tight when installing the coil. Just for safety's sake. Did a hole on a block for the head bolt and never had an issue on torque value.
Yes, blue locktite 242, just in case you have to take it back apart one day.
I also like to use Time-Sert instead of Heli-Coil when I can. It's a tube with threads on the inside and outside. Drill hole over sized, tap threads, screw in the insert, then your stock sized bolt will screw into that.
