VicL
I would like to replace my strut arm bushings on my 1969 and I'm able to remove the nut on the front of arm on the K frame side and also the nut on the lower control arm side. I can spin the strut arm although it has resistance but I'm not sure which side it comes out or if it does. I'm guessing the lower control arm may have to be removed but I'm not sure. Can someone help me with the proper procedure to remove the strut on so I can replace the bushings? I'm hoping that this can be done without removing the lower control arm but I'm guessing that's not likely. Thank you in advance
