Stuck water pump?
EccentricMagpies
10:04 AM
Wisconsin
'74 360 car
I just started the car for the first time since it was Dyno'd .. maybe 3 years now. The car will run and idle, but the blade does not turn. Water pump seems to turn hard by hand.
the belt seemed tight on the alternator but I can't imagine this as any issue.
is this obviously bad water pump issue? I would have thought this water pump was the one used during the dyno of the motor.. but it's been too long for me to remember that detail when I picked the motor up.
Wonder if there might be some other simple solution?
Thanks,
I’m not following something. If the fan didn’t turn and there was a belt on the water pump pulley you should have murdered the belt? Like smoke and all. Do you have clutch fan or is it pump, pulley, fan?
Is this a Keystone Cops routine ? Was the engine ever installed or has it just been on a stand since being built ? Fluids drained ? Water only no coolant ? Like said, it is easy to see the difference between a stuck pump and a stuck fan clutch.
The motor went from Dyno to sitting in the car.
Well, that will be the next thing. Where there might be leaks.
Right now, I only have 4 quarts of Trans fluid in at the moment since it was a rebuild, so I still have to ease that in. (at least from what I was told)
Right now, just happy it starts relatively easy
