Stud/nut kit for 440Source extra thick steel oil pan.
AR67GTX
12:46 PM
Arkansas
Has anyone installed the 440 Source extra thick steel oil pan with a windage tray and studs? I have one on order and I’m wondering if my current 1.3” long studs will be long enough? Most of mine barely have full thread engagement on the nuts now with 2 metal reinforced gaskets and a windage tray. Looks like the next step up is 1.7” which will probably make getting the oil pan in over the crossmember tough unless I install most of them after the pan is put in place with just a couple in to hold it initially.
