Huicho417
- 11:04 PM
- Sep 15, 2020
- San Antonio , Texas
Finally had the first successful cruise around town and got plenty of thumbs up. Felt great to finally do this after working on it for a year and two months. It took a while to get used to the 727 transmission with no overdrive. My other vehicle is a 2014 Silverado. My only complain was as I was about four blocks away from my house. The transmission seemed to be stuck on first gear and would not shift to second gear. I felt if shifting early on, and could easily tell when it would go into second and third. Then downshift as I came to a stop. The drive lasted about half an hour and the max speed I went to was bout 45 mph. I checked the fluid before I left with engine on and in neutral and it was correct.
Is there and adjustment I need to do to the transmission to prevent this on the next drive? Thank you in advance.
