- 1:23 AM
- Nov 20, 2013
- Ft Lauderdale fla.
I spent yesterday putting on the headers... and have blocks of 7/8" wood wedged up against them in a couple of places... one on the collector flange between it and the torsion bar on the passenger side and one between the steering linkage and the top of the headers on the drivers side... I am going to have to cut the bottom of the threads off the inner tie rod and the Pittman arm and some of the nut and bend them down to clear everything... I have read several threads and knew about fitment issues... I'm open to any new suggestions.... what my next move is is to use a large pipe to bend them a little farther than I need and hope they don't spring back... it's just when I hang the rest of the exaust it will have tons of pressure holding them down and away and I don't think the hangars can handle it.. I need the whole weight of the car on my floor jack to move them.... I will leave the wood in place and have the heat of the motor can help soften them as it runs then remove the chared wood later..... I thought of blowing heat from a torch inside the headders but because I just wrapped them it might ruin the wrap... there are two bolts on each side I can't get it their holes on the inside of the outermost tubes also.... I like a challenge and have some pictures I will post.... I will have to modify my column shift linkage also.... it's testing my patience but in the end will be what I want. Doug's or tti would have been easy but more money.... my labors free so I'm not concerned.... a body big block I could under stand but on a small block b body?
