Well, you're looking at $400 or so for the unit, another $300 for the gears, and anywhere from $300 to $700 to get the work done, and that's assuming you take the unit off and deliver it to the shop. That's why I've always found it cheaper to just buy a known good unit with the right gears and be done with it.
Plus swapping centers is very easy to do in the driveway. Just jack up the rear, take off the wheels, pull the drums off, unbolt the axles and pull them out a bit, then unbolt the center and let it fall out. Put a new gasket and some sealant on, put the new center on, bolt everything back up, refill the lube and add some friction reducer, and get the wheels back on and you're ready to go.
