Macdon221
Good Day all,
I had an issue 2 summers ago with the "chatter" in the rear diff during turns. Pretty loud. Both directions. Ordered the clutch plates and had them replaced. Voila all was fixed and great until recently and it is doing the same thing now....noise when turning both ways. Only after the diff heats up after a few miles. If I go around in a circles for a few laps it seems to disappear for the remainder of the ride. Maybe 1500 miles since the first time. Friction modifier was used. Then ran on stands as per the FSM. The diff is original 3.23 date stamped for 68. Original suregrip.
Has the clutches worn again?
I have drained the fluid and changed with new and different friction modifier. No change. I also added more than I should of...just to see. No change.
Any help appreciated.
Macdon221
Macdon221
