Tach install
Bee383
11:03 PM
Yukon,Oklahoma
Installing a tach.i have read a couple of posts on wiring that aren't clear.with elec ign do I still run green wire to neg side of coil or one of the wires from distributor?thanks,David.
With MoPar electronic ignition you run tack signal to the coil negative. Not spliced into the mag pick up in the distributor.
