barbee6043
- 1:30 AM
- Sep 28, 2008
- S E Texas. Shepherd, texas
Are the drums the same as on 66 up ?
Yes that is what I have done with the pre 66 B bodies years back. I have 0ne 66 8 3/4 and 3 pre 66 cars, I plan to sell off 1 or 2 and keep that later 8 3/4 for what I keep. But meanwhile...No, they are different. I replaced early tapered-axle rearends in both my '64's with '68-'70 rear ends. Easier to work on brakes, axle seals, and set axle end play. Straight bolt in.
I am thinking the rear drum for the tapered axle the lug hole are made to be swedged to the hub and the later drums have a little larger lug hole??
'62's had a little narrower rear end than a '64. '66-'67 rear end might work better there, as they are narrower than '68-'70.
NO doubt!!I had a '64 Polara 500, found a Dana out of a '70 and I had the same tire clearance (wide tires and rims) as with the 8 3/4, maybe a bit better. It was a 456 gear and it really woke up that 383!
I got one side to seem to break loose, it made a smallish POP, but it is still hating to come off!
Yes, I have done it before. Really need a drill press to drill in those hard lugs!! Th thread on one of the axles got somewhat boogered as the hub came off, key way probably was the cause. That side really did not want to give. Need a die to chase threads, an idea what the thread count is, 3/4 x ???.Actually Napa has the drums (1965 and later drums, part # ND 4401129). Take care how you remove the lugs from the axle. They are swedged and need to be cut off flush and drilled before forcing them out. If done incorrectly you will ruin the hubs. Read the article I referenced in my previous post to see how this should be done. It's pretty simple.
In post #6 I left you the link to when I drilled mine out. No drill press required. The holes in the hub are a little inconsistent plus the knurling on the new studs can be a little out of shape. Not all of the new studs that I used were tight after pressing them in. Actually tack welded them on the back side for a little added insurance.Yes, I have done it before. Really need a drill press to drill in those hard lugs!!
I've seen the specs on these somewhere. Also seen the info on this site. You might even get ahold of a thread file to straighten them out.Need a die to chase threads, an idea what the thread count is, 3/4 x ???
Yep thats what I am doing.I did this to my '62: http://hotrodsandhemis.com/TaperedAxleBrakes.html
