Temperature sending unit.
chrger1967
12:33 PM
I bought a temperature sending unit off of eBay and it certainly looked like the same one in my Charger. I went to install it and it was just a tad bit too wide. Im talking about maybe a 1/32". Anyone know what part # I should try for a 67 Charger with a 383?
I bought one from Vans Auto LLC through eBay last winter and it went right in and has been working fine. Just searched for it again and they still have it, $7
I recommend the Standard Motor Products TS-17 or the TS-17A (I have this one). After going through multiple senders from Rock Auto that read incorrectly on the stock dash gauge, and doing some deep online sleuthing, I found this one seemed to work for people, and figured I got nothing to lose. Indeed it works correctly and my Auto Meter gauge agrees. Can be had on Amazon cheap, or maybe your local retailer.
Good sender at about 68F should show 320 to 380 ohms.
During my engine compartment refurb I had 2 Standard Motor Products temp senders that would barely register on the factory gauge, both were out of factory spec. I listened to Wayne's advice and sought out an NOS sender.
When these photos were taken the ambient temp was somewhere in the mid-80's F.
Aftermarket sender
NOS sender
Gauge with NOS sender and verified 180-185F with an infrared thermometer.
Yes your bottom photo is where my stock gauge sits when the Auto Meter is at the T-Stat's 180 degrees. Your SMP sender was likely for some other vehicle.
No, I don’t recall the pn# but it was the correct one…
Aftermarket sender
NOS sender
Can these be tested with a multimeter?
The one I bought had the last four numbers 1010. I did see it on Rock Auto, so I think I will try one that was mentioned on this forum that sells on Amazon.
Try a WTBuy and get an OE that works...
@HALIFAXHOPS may have one for you.
Gauge or light? It makes a difference. Let me look in my Filko catalog for a number.
@mobile parts has some good replacements for them. Mine are packed for Carlisle
