tf 727 tv valve
JukkaJ
3:56 AM
Finland
I was installing TF2 kit. I noticed that the TV valve was already grinded to 0.154.
What that means? and should i find new tv valve and grind it to 0.281 what transgo says?
Was there evidence of another brand of kit already installed? Probably safe to grind the additional amount off the T valve to meet Transgo spec.
Mike
This was my first time when i install shift kit. Idont know what kit was istalled allready.
In separator plate hole "d" was allready 3/16. Hole was made when you use drill plate and spacer.
Throttle valve has blue spring. kd lever is 3.8.
