- 11:14 AM
- Jan 14, 2009
- Shoreline, Washington
Continued from another thread that had gone off topic and for some reason won't die out. Apologies to the OP (velrob) of that thread for the hijack.
Maybe it’s time you start yet another thread over in the electrical section about your take on the “ticking time bomb ammeter” bs. This thread’s been hijacked enough, is now way off topic.
With good stud head to copper bus contact, tight clean stud connections, no stud to cluster frame contact, I’d expect you may detect some warming around 100 amps or so. Now, loosen up the connections, get some corrosion between the stud heads and the copper bus, crush the insulators to the point that they no longer center the studs in the cluster mountings and loosens up the connections even further, then dial up some current to see some fireworks.
Are you serious? That’s your back-up for all the BS you’ve posted? The guy behind the counter at the local parts store? We all know about the vast wealth of classic car knowledge and experience that can be had from the kid behind the counter at the corner parts store these days. Know, ask him to explain the inner workings of a carburetor. Try this, ask him for a matched set of v-belts for factory AC compressor/alternator/crank. I was never able to find anyone at those stores lately that knew what a matched set was. At least this explains where some of your mis-information is coming from.Went to Advance Auto today. Couldn't find an ammeter in the "performance section." Asked the dude behind the counter. He looked at me like I was crazy, then said "Why would you want that? Do you want to burn your car up?"
Exactly.
If in fact your car is drawing anywhere near 160 amps pre-start, then your electrical system loads have been highly modified and would not be considered “as originally designed” as I have prefaced all of my factory ammeter comments. What pre-start loads would account for 160 amps curiously?LOL! I was pointing out they had all kind of volt meters, but no ammeter.
Hey, so I figure I'm using 160 amps when I turn the car on before the engine is started. Do you think that is enough to blow the ammeter if I were to listen to your antiquated advice? I think I might burn my old ammeter just to see. I expect it to get REALLY hot before it smokes. Should be fun.
