How rich is rich? Like Niagara falls of gas, engine barely running and black smoke? Was it running fine before this? Any changes? Float level or a stuck float needle perhaps? Stuck choke?
There are 2 O rings in the carb. There placed in the plastic part, in the wells of the top plates boosters. Once these dry out/wear out, fuel floods into the carb.
Stuck float and etc.... from above are good ideas to check.
Rods and jets are very hard to find. I bend AFB rods to fit and clip the ends not needed to tune the T-Q.
Took TQ off car, remove top of TQ, installed two rubber o rings in well, checked float level, set at 1 inch, reassembled and cured my problems, thanks for the good info, learning more about those TQ's everyday:yes:
