Thermoquad Problem..
268RTs4ME
8:08 PM
Polpar Bluff, Mo. 63901
My TQ is running real rich, is there a solution to this problem? Is a rebuild in order, rolling on a 74 440, auto.
How rich is rich? Like Niagara falls of gas, engine barely running and black smoke? Was it running fine before this? Any changes? Float level or a stuck float needle perhaps? Stuck choke?
There are 2 O rings in the carb. There placed in the plastic part, in the wells of the top plates boosters. Once these dry out/wear out, fuel floods into the carb.
Stuck float and etc.... from above are good ideas to check.
Rods and jets are very hard to find. I bend AFB rods to fit and clip the ends not needed to tune the T-Q.
I beleive you are right on the o rings in bottom of well cavity, are probably bad, have a kit coming so will just rebuild, Thanks for the info.
Took TQ off car, remove top of TQ, installed two rubber o rings in well, checked float level, set at 1 inch, reassembled and cured my problems, thanks for the good info, learning more about those TQ's everyday:yes:
