Thinking about tires
jbearden
3:59 PM
Texas
I've been thinking about trying to run a 295/65/15 on a 15x10 wheel with a 5" bs.What do you guys think?Anyone out there running this size?
You're taking a chance of hitting the lower front wheel lip down by the rocker with any tire greater than 28" in diameter. Anything larger may require modifications.
I am running 275 60 15s with 10" wheels. I dont remember the backspace. It fills my wheel wells up good. My tires are 28" and only clear by 1/2" or less.
Ayuh... a 275/60/15 is roughly 28" in diameter so it will fit... a 295/65/15 is considerably larger however..
Looks like the 295/65's are 30" tall. Yeah they aren't going to fit without some major wheel opening mods. 295/55's are 27.8". That's all according to the Mickey Thompson website.
Do you think a 295/55 15 will fit or is a 275 pretty much as big as you can squeeze under it?That would give me a 28 tall and 11.5 wide.Is anyone using their car at the drag strip and what size slicks are you guys running?
I think it could be done with 295/55's. I'm running 295/50/15's on 10" rims with a 5" B.S. so width should be good. As long and the height is less than 28" I would think it would work. You should do some measuring on your car to make sure.
A member over on 66-67 Charger board is running 10 inch wide by 27 1/2 inch tall Mickey Thompsons on a 8 inch rim with a 5 inch backspace. He's running 11.50's@115.
Well the guys here directed me to the 275/60/15 just under 11" in width. your tire is 2" taller and 11.5" in width. I am buying the ones noted so that is all I can input. hope that it helps.
Sounds good guys.Thanks for all the info.I knew that the wheel wells were taller on the Charger than the Coronet so I was thinking that I could get away with a 30" tall tire/29.5x11.5 slick.I will be running a 440-6 pack with a .528 Mopar cam, a 3500 stall and either 3.91 or 4.10 gears (haven't decided which gear set is going in which car yet).It will be making a few trips to the track but mostly be used as a cruiser with plenty of highway miles put on it.
Hey Gpuller, could I see some pics of your car to get an idea of how it looks and sits with 295's?
vbpgimage.php
Here's a couple of mine with 295/50's...
I have better shots, but they're on another puter.
That looks really good!Thank you.I like the stance your car has.What back space and width are you running?
On mine the rear is a BFG 295/50/15 mounted on Cragar 10" rims with a 5" backspace (-12mm offset).
Reed is using the same sizes but he's running a Firestone tire.
Thanks (if your talking about my car)!
Yep I'm running the same rear rim size as 67 Mopar.
