Throttle Cable End Stud
DevEngNerd
1:24 PM
Texas
What do I need to connect the throttle cable end to the EFI/Carb linkage? I made this little bolt stud for my carb and it worked for years, but I want to do it right on the EFI. I bought this little stud kit which looks kind of right but doesn’t fit the throttle cable end.
Yes. But if thats the Holley brand stud, at least on my car, it's too big to fit the cable. Found a stocker.
Might have to drill the hole out on the lever for the stocker to fit.
The EFI should have come with the correct hardware. My Terminator did and before that I had a Sniper and it had the right stuff also. Did you look through all the hardware ?
What make is that unit ??
It’s an Atomic 2, I’ll look through the parts more closely. The instructions don’t mention any hardware, just “you may be able to reuse the stock throttle stud”.
