TallGuy71
Merry Christmas everyone! I don’t expect a reply today hoping that yall had more important things to do but thought I’d hop on here and ask a question. What am I doing wrong? On my father’s newly acquired 71 RR 4sp the transmission was slipping out of gears. I diagnosed issues in the z bar assembly. Proceeded to rebuild and reinstall all of that linkage. Once it was all in, the clutch pedal would not return to the up position so that I had to add a second spring to make it return. I took off the splash shield underneath the clutch to make sure everything looked right inside. I noticed that it seems like the throwout bearing is touching the fingers of the clutch plate even though I had the fork rod adjusted all the way back. What should my next step be?
