1970GTX
ok,
ever since I've owned this car, the clock won't run but the tac works fine. Today I pulled the cluster out, removed the tic toc tac, bench tested it with a hot 12v to the clock. It wouldn't run until I attached a ground to the outside casing and voila, tic toc starts tic tocking. ( apologies ) Next I tested the gray wire which is the 12v source for the clock and there is 12v there. Replace the TTT into the cluster, remount the cluster blah blah blah, ignition on, everything works but the F'n clock. Attack a ground from the outside casing of the clock to a good ground, still nothing. Ideas?
On the up side, I also had an 8 track that would not play. so while I had every thing else apart I yanked the 8 track/radio, took it apart, cleaned everything and removed an inch or two of previously digested tape an I now have music. So I burned about 5 gallons of premium and a little bit of rubber, and listened to CCR and Jimmy Buffet for an hour or so. A good day after all.
Dan
Dan
