1. superbeerick
    superbeerick Member
    15
    9
    Apr 16, 2014
    Washington PA
    Local Time:
    4:41 AM
    Does anyone know the correct ignition timing for an A12?
  2. BeepBeepRR
    BeepBeepRR Well-Known Member
    3,983
    4170
    Oct 16, 2016
    Atlanta,Ga
    Local Time:
    5:41 AM
    12-14 initial & 36 total while im no expert its a good place to start.
    • Agree Agree x 4
    • Thanks! Thanks! x 1
    • moparedtn
      moparedtn Ed on the Ridge FBBO Gold Member
      5,781
      8267
      May 14, 2011
      On the Ridge, TN
      Local Time:
      5:41 AM
      "Officially" (factory specs) it's initial of 5BTDC, vacuum advance disconnected and plugged of course.
      Dual point distributor - Each set of points 27-32°, total Dwell both sets 37-42°.
      • Agree Agree x 2
      • BeepBeepRR
        3,983
        4170
        Oct 16, 2016
        Atlanta,Ga
        Local Time:
        5:41 AM
        5 will get you running. But the car will be a pooch under load.
        • 62MAX
          62MAX Well-Known Member
          1,461
          933
          Jul 21, 2008
          PA
          Local Time:
          5:41 AM
          This !!
          • Like Like x 1
          • Agree Agree x 1
          • Johnpat
            Johnpat Well-Known Member
            757
            734
            Feb 28, 2018
            Missouri
            Local Time:
            4:41 AM
            With today's gas,93oct.start at 12initial
            • Agree Agree x 1
            • 62MAX
              1,461
              933
              Jul 21, 2008
              PA
              Local Time:
              5:41 AM
              Mine's 16 initial,36 total,runs like a clock.
              • superbeerick
                superbeerick Member
                15
                9
                Apr 16, 2014
                Washington PA
                Local Time:
                4:41 AM
                I’ve been experimenting and getting great results thanks everyone.
                • Like Like x 1
                • Kern Dog
                  Kern Dog FBBO Gold Member FBBO Gold Member
                  14,966
                  32628
                  Apr 13, 2012
                  Granite Bay CA
                  Local Time:
                  2:41 AM
                  Maybe ask this chick:
                  • Like Like x 2
                  • lewtot184
                    lewtot184 Well-Known Member
                    4,637
                    2920
                    Aug 21, 2011
                    indianapolis
                    Local Time:
                    5:41 AM
                    factory Prestolite distributor initial timing would be TDC for manual trans, 5 BTDC for automatic. if your using stock/original parts by no means do anything even close to 16 BTDC; 10 BTDC is too much. the factory distributors had a lot of degrees in them.
                    • Disagree Disagree x 1
                    • 8formulas
                      8formulas Well-Known Member
                      50
                      5
                      Feb 15, 2016
                      Connecticut
                      Local Time:
                      5:41 AM
                      I'm at 12 BTDC. Any more initial timing and I'll hear pinging.
                      • RJRENTON
                        RJRENTON FBBO Gold Member FBBO Gold Member
                        799
                        657
                        Jul 1, 2015
                        South Shores area of Decatur, Illinois
                        Local Time:
                        4:41 AM
                        Gentlemen,
                        This is what works for me and my RS23V0A****** GTX: Prestolite dual point distributor with 12° BTDC @ idle (1200 RPM) recurved to yield ~ 22° @ 2600 RPM (no vacuum) for a total of 34° (crankshaft degrees @ crankshaft RPM). Because of the 4.10 gears, it winds up quickly. I use the highest octane fuel l can get (sometimes leaded Sunoco race gas....very $$$ but it runs well) and Champion UJ-11G or HO-8A spark plugs (non projected nose platinum electrodes)....sorry NGK boys. I also run slightly richer fuel ratio (~ 12.5:1 @ WOT) to avoid or reduce detonation because of the 11.0 compression ratio (never again as good fuel was available when I built the engine not now).
                        Just my opinion of course.
                        Bob Renton
                        • Cranky
                          Cranky Banned Staff Member FBBO Gold Member
                          19,920
                          16013
                          Dec 4, 2009
                          Pasa-getdown-dena Texas
                          Local Time:
                          4:41 AM
                          And every engine and combination needs to be tailored to what it likes. Was the engine in question ever rebuilt? Was it rebuilt exactly to factory specs? And is the gas you're using the same as it was back when the engine was originally built? :D
                        1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                          By continuing to use this site, you are consenting to our use of cookies.
